Motherboard Error - Weird Fix?
Solved by airdeano,
- Should I be worried about this experience or
- Should I need to do something to ensure the stability of my PC?
welcome to the Linus Tech Tips forums!
if that was the first time, then just note what you did to correct error and move on.
only if it begins to be repetitive then some troubleshooting will need to be done or
seek manufacturer technical support. usually on POST, if the local driver wasn't
picked up and the device(s) did not pass the POST, then some concern might be
warranted, but one/two times is minor.
USB/SATA issues can be a sign of controller issues (age/time), but so far nothing
right now.
