Phanteks Enthoo Primo WC Help
Solved by Jed,
I have a 360 Monsta in push/pull in the bottom of my Enthoo Primo. I cannot fit the drive cages in. I recommend that you use an adapter and put your HDD in the bottom optical bay. The cabling might be a little messy, but you won't see it due to the shroud.
Ernur ·
Posted in Programming0 -
1
VirusDumb ·
Jayraj ·
Posted in Power Supplies1 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
8
5
ken43 ·
Posted in Troubleshooting5 -
9
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
