HELP ME PLEASE :( :( :(
Go to solution Solved by AustinM,
Thats awesome  :D  :D  :D  :D  :D  :D  :D  :D
Now you can enjoy your first computer build.
Rep wise I have no idea lol.
hahah thank you so much !
I just bought all new parts for my new PC build 2 hours ago and put it all together with out a case because they where out of stock at the place so i got it set up on my desk and i put everything together and booted windows....everything was fine then i put the motherboard drivers in to load them up and it said your driver downloads are complete please restart your PC so i did then it recmended me to start in safe mode. so i did and it dident let me it just went straight back to the screen where i have the option to start in safe mode of normal so i tried normal mode and a blue screen flashes for 1 second then it goes back to the same screen again. so no matter what i click i end up in the exact same option and im stuck, all out of money and just wan't my pc working someone PLEASE help me!!!! :(
https://linustechtips.com/topic/229011-help-me-please/
Reset or clear CMOS
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134255
probably needs reinstalling of fresh OS,
But first try clearing the cmos & redoing the boot process, also check & reseat the power pins & do the same with ram.
totally agree with this statement^^^^
 CPU: Intel i5-4690K  COOLER: XSPC Raystorm 750 EX240 w/ Ice Dragon White Nanofluid MOBO: MSI Z97 GAMING 5   RAM: G.Skill Sniper 8gb 2X4gb 2133   PSU: Corsair GS800  GPU: SLI MSI TWIN FROZR GTX 760 4GB CASE: Phanteks Enthoo Luxe    STORAGE: SAMSUNG 840 EVO 128GB, WD BLACK 1TB, WD GREEN 1TB, SEAGATE BARRACUDA 1TB, WD BLUE 320GB KEYBOARD: Ducky Zero DK2108S MOUSE: Logitech G600
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134261
How do i do that? Please explain in detail :)
See that little round battery on your Mobo? Take it out - wait a few seconds - put it back in. Make sure the right side is up. Done!
Edit: i know theres other ways of doing it but this is the simplest imo...
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134282
On the front of the case there should be a button that is not power, that should be reset, on the motherboard there should be reset button, maybe a button on the IO or remove the battery as suggested  above, what motherboard and case do you have?
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134298
Should i unplug everything from the mobo like all power connectors and keybored/mice ect? and cani keep my cpu and ram in there ang gpu
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134299
You shouldn't need to remove everything just power the system down and remove power lead and then remove the CMOS battery
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134307
2 ways you can do that, But first refer your mobo manual & prefered method would be to find the CMOS Jumper pins in the mobo itself,( there should be a clear set of instruction with picture on the manual follow this & you'll have the bios reset.. )swap the jumper pins give it about 2-5 secs each between the switch & this should be done, it's a hassle free process , do this & post back if it works.. also do this with the power to the mob disabled.
Details separate people.
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134308
No you dont have to unplug anything. But you have to do it while the PC is turned OFF.
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134311
no case, and i have a MSI B85-g43 wuth an i5 4690k cpu
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134320
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134375
 Found it on the MSI website, simplest solution would be to remove the CMOS battery unless you want to play with jumpers that is
dont have good history with jumpers (RIP my AMD rig 2013) so i should just remove the CMOS battery in the middle of my board for a few seconds then put it back in and turn in my pc?
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134389
yeah wait for about 15 seconds or so just to be sure, but seriously, did you read the mobo manual for jumper pin instruction? this shouldn't ve taking this long to clear cmos..
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134401
Yeah try that, also make a note of any overclocking settings you have used and then find out what clockspeeds work on your CPU, RAM (if overclocked) and GPU by overclocking one at a time, I had a similar problem with my MSI Gaming 9AC because my RAM would not work at 2400MHz even if my CPU was at stock (I am now running 2200MHz on RAM and 4.2GHZ on my 4690K)
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134413
Yes i read the mobo manual for the jumper pins, it did not include a jumper when i purchased it but my last motherboard did with my old AMD pc and thats how i messed it up....with the jumpers. Im just going to go ahed and remove the battery and put it back in...start it up and hope for the best :)
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134414
THE ULTIMATE GUIDE FOR YOU
Everything you need is Below plus very detailed steps [sTEP BELOW]
First lets try removing the battery
Steps
  1. Turn off the computer
  2. Unplug the PSU(power supply) from the wall
  3. Remove the graphics card if needed
  4. Pull the metal pin of the battery holder, it should pop out the battery.
  5. Wait 4-5 Seconds
  6. Put the battery back into the motherboard.
  7. Put the video card back (if needed)
  8. Plug the PSU(power supply) into the Wall
  9. Turn on the computer
If that does not work
Lets do a Repair install of windows
Steps
  1. Insert the disk of the windows copy (usb, dvd or other media you used)
  2. Go into Bios (I think its DEL or F4)
  3. Go to Boot Options
  4. Choose boot from the Windows device(the CD, DVD, or USB)
  5. When it loads choose repair install
  6. Let it do its thing.
If that doesn't do anything
Lets call MSI
Steps
  1. Grab your phone
  2. Unlock your phone if need
  3. Call this number
  4. 1 (888) 447-6564
  5. Cry (THIS IS IMPORTANT TO DO  ;) )
  6. Tell them what happened
  7. If they cannot provide a solution
  8. Ask for a RMA
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134415
Steps
  5. Wait 4-5 Seconds
Steps
Lets call MSI
Steps
  1. Grab your phone
  3. Call this number
  4. 1 (888) 447-6564
  8. Ask for a RMA
step 1 failed, trying step 2 but msi bios is confising
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134498
I've never worked with MSI boards so I'll read the manual and pass that off as Reading time in English (YA SENIOR ENGLISH CLASS)
Step 3 always works lol.
https://linustechtips.com/topic/229011-help-me-please/#findComment-3134509
