First Build
Solved by Decon,
I have had some bad experiences with WD drives being DOA so I would recommend a Seagate 7200rpm 1Tb harddrive. Also not quite sure about the corsair vengeance pro RAM DIMMs, gskill and normal corsair vengeance DIMMs are a better bang for the buck IMO. Also might suggest a 970 over the R9 290 since it delivers better overall performance, but if the games you play use AMD technologies, then the R9 is a not a bad option. Build looks rather solid for a first build though.
