Is there any way to add a temperature sensor in the PSU and have it control a PWM fan I want to do this because my PSU fan runs at 100% all the time has to be on the cheap im pretty much broke but I'm finishing up on a GFX deal so should have money within the week
Edit: Dont know why you need it but the power supply is a thermaltake Tr2 600w
https://linustechtips.com/topic/228592-add-a-temp-module/
What power supply?
You could definitely try, but beware when opening the PSU because some of the capacitors can still hold a charge.
If it's still under warranty you could RMA it.
its not a defect so cant RMA and the PSU is a thermaltake TR2 600w
https://linustechtips.com/topic/228592-add-a-temp-module/#findComment-3146431
