Hey guys!
I recently bought a i7-3770k, ASRock Fatality performance and 16 gigs of vengance. However, my computer is slower now then before the "upgrade".
I have reinstalled my windows and all the drivers are up to date. I also have a remarkable fps-drop in-game (LoL, BF3 etc.) The computer just feels much slower now. What the h*ll is the problem?
My gpu is a GTX 660 from Gigabyte
https://linustechtips.com/topic/22821-still-problem-with-my-computer/
is the computer set to high performance power setting?
is the HDD set to AHCI?
have you tried turning off hyperthreading while gaming?
are you playing stuff at the same settings?
is this in windows as well,or is it just feeling slower during games?
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
Yes
not sure
no
all at settings that match my gpu-power
and yes also in windows, starts lagging if I have many tabs open in chrome(max 10 tabs)
I have actually no idea how to turn hyperthreading off btw..
Yes
not sure
no
it should be in the bios,typically in the same part where you have the option to disable cores.
when you say all at settings that match my gpu power,what does that mean?
try putting the GTX 660 into your i5 760 system and try those same settings,does it work worse,the same,or better?
as for AHCI,go to the bios,look for the HDD settings,should have a part where you can select between
-IDE
-RAID
-AHCI
pick AHCI.
after this you'll need to reinstall windows if it was not already set to this when you installed windows.
what are your temps?the cpu may throttling itself down.
download somethign like realtemp,coretemp,or hwinfo to monitor cpu temps.
download something like crystaldiskmark and test the HDD speed,then post your sequential read and write speeds for 500MB
-IDE
-RAID
-AHCI
pick AHCI.
Im maxing out the games i can if I get 50-60 fps, in bf3 High-settings for example.
The HDD is set to AHCI. The temperatures is 40 celsius idle and 65 at max load with the stock cooler.
I tried some other HDD test and max read was 145 mb/s and lowest 56 mb/s
another thing to check is make sure your ram frequencies are set right I lost 10-20% fps in a couple games because I forgot to set my ram from 1333mhz to 1866mhz after a cmos reset
I thought that was the problem at beginning too, apparently so was not case ( it was actually at 1866mhz instead of 1600)
