So I'm building my first pc. I'm building in an NZXT H440. mobo is ASROCK Extreme 6. Corsair H100i. HX750i power supply.
First problem I've run into is I swapped out the stock fans for sp fans, well, the new sp fans have very short cables. Is there an extension cable I can buy for those front 3 fans that can't make it to the mobo? Also the sp fans have a 4 pin connector so the extension would have to be a 3/4 pin for mobo to 4 pin to connect the fan. This mobo only has 4 fan connectors. 3 chassis fans, and a power fan. not including the 2 cpu fans which are occupied by the h100i. Help please...
https://linustechtips.com/topic/226552-much-needed-help/
Should have got a Noctua NH-D15 OP.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/226552-much-needed-help/#findComment-3103389
