Good day guys, I have had HP ProBook 4530s for about 4 years. There was only one problem, about 4 months ago, when my HDD stopped working. It was replaced with an SSD and I installed Win 7 Pro.
The problem is that yesterday, my notebook refused to connect to wifi in school, but when I entered a second building, it started working immediately. However, when I got home I could not connect to a normal home network (other devices connect withount a problem). So I looked at the network and I found out that my notebook connects, gets its IP, gateway pretty much everything it needs to connect. But I cant ping my modem and it says: "Internet connection is not available".
I tried to download and install drivers but there was no change. Also when I use ethernet cable, everything works allrgiht.
Does anyone have any idea where might the problem be?
Thank you for your help
https://linustechtips.com/topic/225768-notebook-wi-fi-problem/
