LOGISYS Case Lights - Anyone tried them?
Solved by ChaoticWeaponry,
I personally would just get a long strip of LED's and wire them myself. I've used logisys cold cathode lights before, but they're bulky and you have to find a place to put the inverter.
I use these LED's, and the length is good for many, many builds.
You can get them in green, blue, and red from what I've seen.
