cpu idle temp 65
Go to solution Solved by alphabeta,
I found out that the problem is with the program I used to monitor the temp itself
AMD temp monitoring on idle is gash, what about under full load? what are temps like there?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/225581-cpu-idle-temp-65/#findComment-3090091
That is too hot dude. Is your cooler good installed.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/225581-cpu-idle-temp-65/#findComment-3090118
Either you've not installed the cooler right, or the sensors are borked.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/225581-cpu-idle-temp-65/#findComment-3090126
Yes but thermal paste not wuiet sure
Uninstall it. And do everything again. Then you are sure, You are not OC'ing right?
https://linustechtips.com/topic/225581-cpu-idle-temp-65/#findComment-3090140
Sensors?
http://help.argusmonitor.com/index.html?TemperaturemeasurementforAMDCPUs.html
"The value for the CPU temperature of the (digital) on-chip sensor does not equal any real physical temperature but is measured on an AMD spezific scale"
https://linustechtips.com/topic/225581-cpu-idle-temp-65/#findComment-3090147
