Difference between Full-Screen and Borderless(Full Screen Window)
Go to solution Solved by clementk,
Is there a difference? I like to use borderless so I can alt-tab out of games faster, but not having the green check mark in GeForce experience is annoying me.(They recommend full-screen)
  when you run applications in full screen mode they run in "exclusive mode" That means it has full and direct control over the screen output.
where windowed has to go though something like explorer so it can be slowed down
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
Never used windowed or borderless windowed mode ever in my whole life
I just full screen everything
Please remember to follow your topics ;)
The difference is that when you alt-tab the game is treated like any other window, however the window border is removed. You may loose a little performance from this, but nothing significant.
sudo chmod -R 000 /*
Needs Update
