New PC build help
Go to solution Solved by jtai117,
PCPartPicker part list: http://uk.pcpartpicker.com/p/MMk4P6
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  (£219.54 @ Aria PC)
Motherboard: Asus H97-PRO ATX LGA1150 Motherboard  (£82.76 @ Scan.co.uk)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1866 Memory  (£114.29 @ More Computers)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  (£146.99 @ Aria PC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  (£71.94 @ Aria PC)
Case: Cooler Master Storm Scout 2 (Black) ATX Mid Tower Case  (£59.99 @ Scan.co.uk)
Power Supply: Super Flower Leadex Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£84.59 @ Overclockers.co.uk)
Total: £780.10
Generated by PCPartPicker 2014-10-01 15:24 BST+0100
This should keep you going for a long long time. The i7 and the 16GB of ram is there more for editing than anything. 512GB SSD for 1 or 2 current editing projects and the 3TB HDD for general storage. The Asus H97 PRO is the best H97 motherboard you can buy and the Super Flower make some of the best PSUs on the planet. 650W should be more than enough for 1 and maybe even 2 GTX970s. Comes up to about 1000 Euros.
Hello, I'm gonna build a new pc but not to sure what parts to get.
I have found the case I want to use, the CM Storm Scout 2. I mainly choose this one for easier transport.
I'm gonna be using it mainly for gaming, but other editing stuff too..
I have a budget around 1200 - 1500$
Thanks in advance.
edit: I live in Denmark (europe), I allready have a gpu and cd drive, and I dont need any monitors or other peripherals.
https://linustechtips.com/topic/225262-new-pc-build-help/
I'm gonna be using it mainly for gaming, but other editing stuff too. I only play league of legends and sometimes BF4, so dot need the most expensive gpu.
Thanks in advance.
Location? Do you need peripherals or a monitor? Are you reusing any parts? Do you want a CD drive?
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3087548
gonna have to use the UK PCPartPicker and convert to euros. I hope the prices are somewhat similar =/ What GPU do you have btw? Also, did you want to overclock?
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3090719
I have a GTX 760. I have never overclocked before so not gonna.
Are you willing to not use that GPU? You can probably fit in a GTX970 into the build. If you want to use the 760, you don't need to spend 1200+, you can get by with spending less than 800 euros
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3091148
I want to use the 760 for now, then maybe upgrade later.
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3091183
Total: £780.10
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3091272
Total: £780.10
What about a CPU cooler, heard that the stock cooler is bad?
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3091552
if you're not overclocking, the stock cooler will do just fine =]
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3091624
Alright, thanks alot,
No worries. Good luck.
https://linustechtips.com/topic/225262-new-pc-build-help/#findComment-3094419
