mm Fans?
Solved by Mateyyy,
Most cases support 120mm and 140mm fans these days.
Usually, on the manufacturer's website, or on the case's box, you can see all the fan spots and the fan sizes that fit.
You can check out this video to understand this a little bit better:
errorcode123_dindin1 ·
Posted in General Discussion0 -
Packhunter ·
Posted in Graphics Cards0 -
5
2
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies3 -
Airmack ·
Kyle89 ·
Posted in Troubleshooting2 -
8
5
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
