Hello,
Where do i mount my pump, I have a define r4 and i could find a place, but what do pumps/reservoirs use to mount.  I don't want a 5.25 inch bay reservoir pump combo.
Thanks
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/224355-water-cooling/
how is that pump/reservoir mounted, is it just sitting on something or is it screwed in or what
https://linustechtips.com/topic/224355-water-cooling/#findComment-3073227
Looks like it is sitting on the hdd cage, more than likely screwed  down somehow. I've heard if you buy some really strong 3m two sided tape  you can use that stuff as well. I forgot exactly what it was, but I have seen people use it to mount pumps, hard drives etc.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/224355-water-cooling/#findComment-3073256
Thanks, I'll do that
https://linustechtips.com/topic/224355-water-cooling/#findComment-3073379
I think I have seen some that can hold up to 65lbs (maybe more can't remember) by 3m in my lowes a few months back. Something like that would work.
https://linustechtips.com/topic/224355-water-cooling/#findComment-3073392
