I would take off the Fan and the cpu cooler those are easy upgrades to make when you have the money.
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/224315-need-help-planning-build/#findComment-3072727
A little better?
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($233.97 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($33.98 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97N-Gaming 5 Mini ITX LGA1150 Motherboard  ($132.98 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($82.99 @ Newegg)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($74.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 285 2GB WINDFORCE 2X Video Card  ($249.99 @ NCIX US)
Case: Fractal Design Node 304 Mini ITX Tower Case  ($89.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($28.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($99.99 @ Newegg)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($13.99 @ NCIX US)
Total: $1016.86
Generated by PCPartPicker 2014-09-28 23:06 EDT-0400
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/224315-need-help-planning-build/#findComment-3072741
