ok so ive got a pre OCed gpu will i need to get a Z97 mobo? or can i get something cheaper? heres my build, im trying to make it cheap where it can be cheap but worth the money where it can be http://pcpartpicker.com/p/JKpCCJ thanks
overclocking is dependant on the gpu not the motherboard. And that would be fine.
Although, if theres any chance you may want to SLI or XFIRE in the future then it would make sense to get a better motherboard -- Something like an MSI Z97 G55 SLI.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/223355-overclocking-mobo-help/#findComment-3059943
can anyone recemend a good cheap mobo?
PSU Tier List | CoC
https://linustechtips.com/topic/223355-overclocking-mobo-help/#findComment-3060361
i dont think im going to be doing sli or xfire
im trying to be as cheap as possible without sacrificing too much, i just want a mobo that wont fuck up and will handle my hardware. could someone recommend a mobo like that?
im trying to be as cheap as possible without sacrificing too much, i just want a mobo that wont fuck up and will handle my hardware. can you recommend a mobo like that?
https://linustechtips.com/topic/223355-overclocking-mobo-help/#findComment-3061079
Any z97 board from Asus, MSI, or Gigabyte.
PSU Tier List | CoC
https://linustechtips.com/topic/223355-overclocking-mobo-help/#findComment-3062052
