Need help with compatibility
Go to solution Solved by ThomChild,
Thanks for the answer mate!
I actually did a lot of researches for the best case. I was settled on the 750D when I found this one. I thought it was pretty great for my needs. Hope I didn't go wrong...  Got it for 89 $CAN, isn't that cheap for this kind a low noise case? the 750D was like 150. Anyway, just trying to convince myself because it's already bought...
I am seriously concerned about the GPU / heatsink clearance. So I decided to go with a smaller cpu cooler. The cooler master hyper 212 Evo. Is that a good idea? It's cheaper, have good reviews, gets decent performance for OC....
Hello everyone,
I'm struggling to chose the cpu cooler for my new build, which include the Asus x99-deluxe motherboard in a Fractal design define R4 case with a Asus GTX 980.
I would love to go with the NH-D15, but I'm not even sure it can fits in the case, plus i fear it may come too close to the GPU. So I thought going for a corsair h100i cooler which can fit in the top of the case, but I fear it won't fit in this scenario because of the x99-deluxe top heatsink.
Any suggestions? Any answers? Is one of my two options any good?
Thanks in advance!
Éric
https://linustechtips.com/topic/223259-need-help-with-compatibility/
Newegg being Newegg, I can't find more information on what heatsink sizes are supported and I don't feel like rummaging thru other sites right this second.
I will tell you for sure that the H100i will not fit, or it's way too close to try. I would've suggested you have the top HDD cage removed and throw the H100i in the front but the R4 only supports 120/140/280mm in the front and not 240mm. That and I don't know if the hoses would be too short or something like that (again, more info that I don't care to look up).
May I ask why you'd spend $900+ on a platform and then throw it in a mediocre case, especially one that's heavily overpriced in comparison to similar products? I'll double check it right now but I think the Enthoo Pro is a very similar case that should house everything with ease, and it's the same price.
Edit: It looks fine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811854003 - Product page (with lower price than the R4).
http://www.phanteksusa.com/products/phanteks-enthoo-pro - Link so you can look at all official specs for yourself.
H100i and NH-D15 both fit with the Asus X99 Deluxe from the looks of it, but check for yourself to see for sure..
Forgot to answer your question about the D15/GPU clearance.
It should be fine, I believe you can orient the fans so that they push/pull front to back inside. I would be far more concerned about the RAM clearance with a lot of DDR4 when picking coolers myself though.
Edit: It says it does support the X99 Deluxe, way down at the bottom under Asus. There are no "If's" listed.
http://www.noctua.at/main.php?show=compatibility_gen&products_id=68&lng=en
