Unbalanced, you would be better off getting an I5-4690K or (if you do not want to OC) a Xeon E3 1231v3 and a Z97 PC MATE from MSI (Best budget ATX motherboard without sacrificing upgradeability). If you really want to future proof it a bit more AND you want to OC (I think games will use more than 4 threads in 2015 making I7's/FX-8320 attractive) then get an I7-4790k. If you're not OC'ing though get the Xeon E3 1231v3. Also get a better PSU. The CS550M, CX500M are good choices if you plan to stick to one card. Otherwise the Corsair RM750, EVGA G2 750W are good choices for 2-way SLI
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/222623-new-pc-build-help/#findComment-3050903
Looks quite ehhh wierd if you ask me, if you are gonna step up the GPU atleast put in some extras like a SSD, a better PSU like corsair RM750 or CoolerMaster V750S. Also get a K version of the CPU and put a closed loop water cooler on it and overclock it to maximize the power it can deliver.
https://linustechtips.com/topic/222623-new-pc-build-help/#findComment-3050998
http://pcpartpicker.com/p/xsCPvK is this good .my buget is $1000 .i may be able to increase by 100 or 200 dollars <_<
You better get a k version CPU and a Z97 Mobo even if you dont plan to OC now, since it's just generally better and about 3-4 years from now when it's become too slow compare to other new CPU, you can OC it to gain a few more months/year from it life time. As for the GPU, it fall under the same problem as the 780TI vs the 780 back then, the performance gain the 980 have over the 970 is quite good but for the extra 220$ you have to pay, not really. So I'd say you better get a 970 with an SSD instead.
Overall, this is what I suggested:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($239.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.52 @ OutletPC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($129.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($86.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($85.59 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($53.98 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($349.99 @ NCIX US)
Case: NZXT Source 210 Window ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($55.98 @ Newegg)
Total: $1036.02
Generated by PCPartPicker 2014-09-26 08:58 EDT-0400
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/222623-new-pc-build-help/#findComment-3051052
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.66 @ Amazon)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($89.99 @ Micro Center)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($72.00 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 980 4GB Video Card  ($549.98 @ NCIX US)
Case: Corsair Graphite Series 230T Grey ATX Mid Tower Case  ($53.99 @ Amazon)
Power Supply: Corsair CSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($93.95 @ Amazon)
Total: $1177.55
Generated by PCPartPicker 2014-09-26 08:59 EDT-0400
I was able to squeeze a 4690K along with a decent CPU cooler for the ability to OC along with the same GPU.
Also switched the Blue out for a Barracuda, just a preference, but it's also cheaper.
Actually didn't realise that I put the same case in as the one you already listed lol, but yeh the 230T at that price is pretty dam good.
Also I put a CS550M in there for the 80+ Gold and semi-modular features.
Put in some normal 1600MHz CL9 RAM, just because in gaming it has little to no effect on fps.
I also improved on the motherboard, instead of a B85M, the PC Mate motherboard from MSI has a Z97 chipset.
Edit:
Wow, just typed like another 200 words about you being new and welcome, and what you needs to do before you do anything else, then I pressed cancel instead of Save Changes.
*sigh*
@gameplayer778 Be sure to follow your thread next time, that way you get a notification every time someone posts a comment on your thread.
Also make sure that you read the Code of Conduct and stickies in the subforums before you post again so that you know all relevant information about the forum and more specifically the sub forum.
Don't forget to quote a member's post so that they get a notification so that they know that you responded to their post.
Hope you enjoy yourself on LTTF :D
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/222623-new-pc-build-help/#findComment-3051108
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($338.95 @ OutletPC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($72.00 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ OutletPC)
Video Card: EVGA GeForce GTX 980 4GB Video Card  ($549.99 @ Amazon)
Case: Corsair Graphite Series 230T Grey ATX Mid Tower Case  ($44.00 @ Newegg)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $1205.42
Generated by PCPartPicker 2014-09-26 09:29 EDT-0400
i5 may be the good option now but i7 would be a good investment when dx12 comes out and games stats utilizing more than 4 threads
if got more money get a decent board wiith proper number of power phases like ga ud3h
https://linustechtips.com/topic/222623-new-pc-build-help/#findComment-3051264
