Hi
I have thousands of pirated games and softwares on my hard drive. From now I have decided
only to use free or legal softwares :)
So my questions would be,
1) Would Dod 7 pass overwrite wipe all of the data on HDD and make it run like in the factory
state? I meant would it fully clean my hard drive?
2) On a forum I found I saw that filling the HDD with 0s would help to make sure that
every single data is gone. Is this true? If so how should I do it?
Thanks for any help :)
Btw It's a Seagate Barracuda 1TB Hard drive
https://linustechtips.com/topic/222014-fully-cleaning-a-hard-drive/
If you want all the data gone open it up and break the platters. Otherwise it is still recoverable by someone  if they put enough time into it. Just format the drive and use it from there, it doesn't have to be that clean.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
Hey there, @ShaunKay!
Yes, writing zeroes will perform a full erase.
I suggest you download the tool from your manufacturer, where you will find this option.
This will wipe out all the data on the drive. It might take longer, but it helps to ensure that no data on the drive can be retrieved later using Data Recovery methods.
Hope this helps. :)
I hope I can help with any storage issues that you may have!  ;)
