Hi guys, when I try to export some image, the exported image is different from the one which is in Adobe LR. But when I'm trying to view the exported image in Adobe PS or LR, the image displays correctly.
Do you have any idea what causes this, and what workaround I can do to export it correctly.
By the way, Source Photo is JPEG and will be exported to JPEG 100% in sRGB color settings.
Kindly check link below to visualize what I'm trying to say, and to view the full image comparison.
Image 1:
https://www.dropbox.com/s/tconi3o4xmwipii/lr-3.png?dl=0
Image 2:
https://www.dropbox.com/s/3tcts77hlb2t1v6/lr-2.png?dl=0
"Cough, Cough, Cough"
https://linustechtips.com/topic/221964-adobe-lightroom-export-problem/
When you export, is there any options checked that might change the final results. Did you look into thoses different options.
"Strength does not come from winning. Your struggles develop your strengths. When you go through hardships and decide not to surrender, that is strength" Arnold
Ok, I found out what causes this, it was Lighroom's color space. I tried changing the working space via Profile on my Adobe Photoshop the export were now the same, however I couldn't find any other way to fix it in lightroom. >_<
Sorry links don't work. Maybe you have selected a different image when you have exported? Maybe you have synced with differnt setting or something.
Hi, thanks for informing about broken links. I've updated it now, and should be working by now.
Interesting. I do see the difference. Can you show me your export settings.
Somehow I finally figured out how to make the exported image identical from my LR.
I just changed the color space from sRGB to my monitor's color space. Now, I wonder how does my image looks like on other monitors.
