Hello i am going to build this build
The build says i need a ASUS GTX Titan 6GB is that the same as the ASUS GTX Titan black 6GB as i can not find the ASUS GTX Titan 6GB in the uk? Also if i do use the black will it still work with the VGA Block??? Thank you
Specs
CORE COMPONENTS
CPU: Intel 4770K "Haswell" Unlocked Processor
SSD: 2x Intel 520 Series 240GB SSD in RAID 0
Motherboard: ASUS Maximus VI Extreme
Case: Corsiar Obsidian 900D
Video Card: 2x ASUS GTX Titan 6GB
Sound Card: ASUS Xonar Phoebus
Storage Drives: 2x Western Digital Red Edition 3TB in RAID 1
RAM: Corsair Dominator Platinum 2400MHz 32GB
NCIX: http://bit.ly/1ck7syG
Power Supply: Corsair AX1200i
Blu-Ray: ASUS BW-12B1ST
Headphones: Beyerdynamic Custom One Pro
Amazon: http://amzn.to/19TSvRX
Mouse: Razer Deathadder 2013
Keyboard: Logitech G710+
NCIX: http://bit.ly/15k2eZS
Monitor: ASUS PB278Q
Amazon:
Cooling Components
Fans: 17x Noctua NF-F12
NCIX:  http://bit.ly/198lbE0
Fan Splitter: Swiftech PWM Fan Splitter
CPU Block: Koolance 380i
NCIX: http://bit.ly/16A5ZNF
VGA Block: Koolance GTX Titan x2
Tubing: Primochill Primoflex LRT Advanced
NCIX: http://bit.ly/11RQctV
Fittings: Koolance 3/8ID 5/8OD Compressions
Radiators: Alphacool Nexxxos XT45 All Copper Radiators
Quad Radiator: 2x http://bit.ly/16A6gjP
Triple Radiator: http://bit.ly/15X7kBx
Dual Radiator: http://bit.ly/1cA6lKq
Single Radiator: http://bit.ly/13p1OSC
https://linustechtips.com/topic/221957-help-with-this-build-on-gpu/
