I wouldn't get an APU if you're getting a GPU as well. a GTX 750ti would be my recommendation for an ITX build, as they run pretty cool in a confined space. a 270 if you're not worried about temps too much
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/221802-mini-itx-build-gpu-help/#findComment-3040257
evga superclocked 750 ti was a great option for my itx build. Runs cool, has prettty descent perfomance/price and doesn't require any extra power cables. Also is really short so you shouldn't have any trouble fitting it into a build.
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/221802-mini-itx-build-gpu-help/#findComment-3040289
1.) Why? linustechtips.com/main/topic/221665-mini-itx-build-help/
One post should be enough.
2.) http://pcpartpicker.com/part/msi-video-card-r9270gaming2g
That's the one I would get. You have good cooling in your chassis, so that should not be an issue. Also this card is very quiet and cool, and it overclocks easily to the performance of a 270X. Just put all sliders to the end, done! Slick did that in the LTT video and my buddy has that card and it actually really works. Easiest OC ever.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/221802-mini-itx-build-gpu-help/#findComment-3042098
