best CPU cooler for OC?
It would help to know what cpu you're planning to cool and how far you intend to oc as well as what case/motherboard/ram you're using in case there might be clearance issues. .
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3021697
oh, i would like to OC my i7 5820K, if possible.
and i'm using the MSI X99S SLI Plus ATX LGA2011-3 Motherboard with ram with not cooler
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3021709
Within your price limit, the Dark Rock 3 i'd say.
Your chip has a 140 TDP, that cooler supports up to 190 TDP.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3021742
What ram and case are you using?
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3021981
I'd suggest going with the Dark Rock 3 in that case. It doesn't really get much better for under 50 pounds atm.
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3025914
would crosair h60 be good for OC? becasuse i can have 60 pounds to a watercooler, becasue i can buy one less fan in the case
The Dark Rock 3 performs better and is quieter than the H60: http://www.hitechlegion.com/reviews/cooling/heatsinks/38959-be-quiet-dark-rock-3-cpu-cooler-review?showall=1&limitstart=
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3028257
what is the best CPU cooler for CPU which is under 50 pounds?
wow thats a heavy cpu cooler lol (just joking) and id agree dark rock 3
Project black out: cpu: athlon x4 750k @4.7ghz, Mobo: asrock fm2+ a55 vg3+, ram: 1x 8gb hyperx 1866mhz, video card: 1x saphire radeon r9 270x, Storage: 1tb hdd ssd in the future,  cooling: 2 noctua 120mm fans 1 on rad one front intake.
https://linustechtips.com/topic/220437-best-cpu-cooler-for-oc/#findComment-3028449
