CPU Overheating Issues
Go to solution Solved by Faaa97,
Is cooler installed properly? Also try changing thermal compound.
I have a friend who just built a new editing pc and his cpu overheats to the point of the pc shutting down whenever he tries to render something, it usually gets to 95+ then shuts down it has a stock cooler but shouldn't that at least keep it from overheating?
this is his build:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($247.94 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($82.98 @ Newegg)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($149.99 @ Micro Center)
Video Card: Asus GeForce GTX 780 3GB DirectCU II Video Card  ($437.99 @ NCIX US)
Case: Silverstone PS07B MicroATX Mini Tower Case  ($79.98 @ Newegg)
Power Supply: Rosewill 650W 80+ Bronze Certified ATX Power Supply  ($60.05 @ Amazon)
Monitor: AOC i2267Fw 60Hz 22.0" Monitor  ($129.99 @ Micro Center)
Total: $1326.89
Generated by PCPartPicker 2014-09-22 16:47 EDT-0400
is there any software we can at least get to stop the cpu from stressing when it hits like 80 degrees? just need something to hold him over until he can buy a hyper 212 evo.
btw we ran some benchmarks like heaven and firestrike and the cpu didnt go above 75 however it just dies when rendering we also do have cuda rendering enabled so it should be using the 780 however it dosent go over like 40 when rendering for some reason.
"Anything that makes a console more like a PC, makes it better"
-Linus Sebastian
https://linustechtips.com/topic/220408-cpu-overheating-issues/
I would ask the same with Faaa97 +did he clean the CPU surface before instal the cooler? Is there enough airflow through the case?
there is enough airflow but now that i think about it i probablly should re apply thermal paste
-Linus Sebastian
https://linustechtips.com/topic/220408-cpu-overheating-issues/#findComment-3021483
