so i could use a single link hdmi to dvi for my new monitor (dvi would be on the monitor end with hdmi as the gpu output) or i could use a dual link DVI for the monitor coming from a DVI-D connection.
option 1: single link DVI from HDMI
option 2: Dual link from DVI-D
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/220367-what-cable-should-i-use/
It doesn't really matter, but I'd use DVI just because it locks. Picture quality will be the same.
My PC: MSI X99s SLI PLUS///Intel i7 5820k///Corsair H100i///Crucial DDR4 12GB///EVGA Supernova Gold 750w G2///ASUS GTX 1080 Strix///Phanteks Enthoo Luxe///Intel 730 240GB SSD///WD Blue 1TB///Intel 6250 WiFi
Current Peripherals: Sennheiser HD598///Corsair K70 LUX///Logitech MX Master///Razer Destructor 2///Saitek X52///Acer X34 Predator
https://linustechtips.com/topic/220367-what-cable-should-i-use/#findComment-3020738
Really doesn't matter, they both will give the same quality.
https://linustechtips.com/topic/220367-what-cable-should-i-use/#findComment-3020783
