So i bought a new motherboard Asus Maximus Formula VII Z97.
I kept my 4770k and put it in the new board. I'm using a H100i water cooler
On my old Z87 board the cpu temps were really gradual rising 2-3'c at a time.
On my new board its more like 25'c in one jump. also the idle temps seem to jump around the 25-33'c wildly instead of a 1'c change on my old board.
Temps on high useage seem about 10'c higher as well. folding used to give me 42'c now its about 55'c although the ambient temp is a little hotter.
Do i have a faulty sensor?
Is there any good (free) software that i can use?
any bios settings that i can check/ change?
If you read the same things as others and say the same things they say, then you're perceived as intelligent.
I'm a bit more radical... Woz
https://linustechtips.com/topic/219445-fluctuating-cpu-temps/
What are you using to check the temperature?
I always use MSI Afterburner for system monitoring, though HWMonitor is also good. CPU-Z is focused on CPU monitoring so you might want to check that out too.
Also just be sure to update your motherboard and CPU drivers, along with installing the newest BIOS version.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/219445-fluctuating-cpu-temps/#findComment-3008326
using Hwmonitor its giving me temps on my core's of 70'c whilst folding. seems way too hot for my liking, although asus suite says 59'c.
I have updated the bios, i installed the motherboard drivers going to check that they are up to date now. although i haven't heard of cpu drivers where would i get them from?
https://linustechtips.com/topic/219445-fluctuating-cpu-temps/#findComment-3008378
I have a 4770k and a h100i as well. Ever since I built my system or installed my h100i (not sure which) it has done the exact same thing. Right now it is jumping back and forthwith a 7c diff every half second. I have no idea why it does it and haven't found anything to fix it, it has a stable temp under load but fluctuates wildly when idled. But any case just letting you know you're not alone and hopefully it makes you feel better. 11 months of having this computer doing this and everything still works fine.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/219445-fluctuating-cpu-temps/#findComment-3008413
Ah sorry, being a bit dumb atm lol.
Only CPU drivers for the iGPU :P
Try out MSI Afterburner and CPU-Z, I've had some problems with HWMonitor so there may be some problem with it.
https://linustechtips.com/topic/219445-fluctuating-cpu-temps/#findComment-3008424
Yeah it seems fine ive had it running for a few weeks. the temps are the only thing thats annoying me. im pretty sure the temps aren't accurate.
Ah i see well il check them as well. I think its a faulty sensor because after burner is giving me temps of 150ish aha. although 50 on each core. might have look in the bios see if theres any setting there.
https://linustechtips.com/topic/219445-fluctuating-cpu-temps/#findComment-3008494
