I5 4690k OC problem
Go to solution Solved by ind3x,
How are you trying to adjust it? By clicking?
You have to use your numpad +-
(a lot of people make this mistake)
Turn off OC genie. Then the settings should unlock. At least there should be a setting somewhere that sets it to auto, just set it to manual
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/218968-i5-4690k-oc-problem/#findComment-3002273
I turned it off, still doesnt works...
Put the CPU ratio on manual?
https://linustechtips.com/topic/218968-i5-4690k-oc-problem/#findComment-3002347
You can also highlight the field and manually type the value you want. Say stock is 35, you can just highlight it and type in 43 and enter from there.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/218968-i5-4690k-oc-problem/#findComment-3004696
Like me just today. Same mobo than with OP. Oh well, got it running. Another quick google was for finding LLC setting.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/218968-i5-4690k-oc-problem/#findComment-3010322
