Java problem.
Go to solution Solved by fizzlesticks,
switch(arg[arg.length() - 1])
Should be switch(arg.charAt(arg.length()-1))
I am making a program and I can across a problem. It compiles but doesn't run the way I want it to.
So I made a simpler copy without the program specific stuff.
Here's the code:
class test{    	static String argIs = "The argument is:";	static String otherArgIs;	public static String Hello(String arg)	{		if (arg.toLowerCase() == "hello")		{			return argIs + " hello";		} else if (arg.toLowerCase() == "hi")		{			switch(arg.length() - 1)			{				case 'i': otherArgIs = argIs.substring(0,argIs.length() - 1);						  return otherArgIs + " hi";				default: return "error1";			}		} else return "error2";	}	public static void main(String[] args)	{		System.out.println( Hello("hello") + Hello("hi") );	}}
I want it to output "The argument is: hello" and "The argument is hi", but it outputs "The argument is: helloerror1"
Also, don't pay attention to the uselessness of this program. The actual program is somewhat more useful.
https://linustechtips.com/topic/217814-java-problem/
In your switch statement you have
case 'i':
 which is a letter and not a value to compare against the length. So it goes with the default case.
Also
is concatenating the string results together without a space or line break.
https://linustechtips.com/topic/217814-java-problem/#findComment-2987188
1) Instead of arg.toLowerCase() == "whatever" do arg.toLowerCase().equals("whatever") otherwise there may be errors since == will compare references and not the actual content. Sometimes it works because it assigns the same object to the same string literals but not necessarily ( http://stackoverflow.com/a/513839
2) switch(arg.length() - 1) will search the cases for a number, not a character, you probably want something like switch(arg[arg.length() - 1]) (something like that)
https://linustechtips.com/topic/217814-java-problem/#findComment-2987200
