Hi all so wired network connection was working fine
until yesterday now I get the error 'Local Area Connection doesn't have a valid IP configuration
My network setup is
Router/modem>Power line>powerline>Desktop
My laptop can connect to the network and seems to work fine over wireless
I have tried reinstalling the Ethernet driver
as well as these http://www.techsupportforum.com/forums/f31/solved-local-area-connection-doesnt-have-a-valid-ip-configuration-683968.html
The Local area connection has Unidentified network below it
I have ordered a new Ethernet cable which arrives tomorrow
I am using Windows 7 ultimate using a Asus Maximus vi formula using the onboard Ethernet connection
Any Ideas?
ps and no I cant directly connect to the router due to the router having poor wireless
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/217453-wired-network-problem/
Have you tried setting a static IP address? Also try resetting the powerline plugs ^ ^.
Yes I have done both to no effect
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2981841
I would say it'd be worth plugging the laptop into the wallplugs via ethernet not wireless to find out if the problem is with the plugs / cable or the router / desktop.
I7 3770K | GTX 770 amp! | 12gb DDR3 @1600mhz | 250gb OCZ Vertex 450 & 2TB WD Black
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2981867
The laptop doesn't detect the ethernet cable so it's the cable or powerline that's the problem right?
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2981928
That would make sense. I'm not sure what powerline model you are using but if you haven't already it may be worth trying to reset it. Sometimes I find if you try resetting it while they are plugged into the same outlet right next to each other at the same time it'll find it faster.
If that doesn't work, check the cable itself by plugging it directly into the router and using your laptop. If the cable works fine then it's probably the powerline plugs.
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2982007
Just tried plugging direct to the router but my laptop wasn't able to pick it up
which is very odd
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2982815
which is very odd
If you've got another ethernet cable try using that. Also if there are any other ethernet ports in the back  try using those as well.
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2982933
Just did that sadly makes no difference
https://linustechtips.com/topic/217453-wired-network-problem/#findComment-2983746
