I would say it's not worth it at all, in fact I don't see how this would work at tall. You can't cool it any cooler than room temperature.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/217448-water-cooling-the-case/#findComment-2981422
The concept of watercooling is to circulate the water through some heat dissipating/distributing surface and take out that heat through air. which in your case there is no heat to take off the case itself as it stands nearly = to your room temperature. which is what air temperature in your room. so it's not worth it.. simply if you want using cooler air than the one in room temperature you are going something else, phase change or using Huge chillers.
https://linustechtips.com/topic/217448-water-cooling-the-case/#findComment-2981467
Me I thought about using the system Fridges have to cool my case ( the inside ), the system would keep the inside at 2 degres at all time. that would be great.
"Strength does not come from winning. Your struggles develop your strengths. When you go through hardships and decide not to surrender, that is strength" Arnold
https://linustechtips.com/topic/217448-water-cooling-the-case/#findComment-2981471
you would effectively have to turn your case into a refrigerator, and then have to deal with condescending condensation.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/217448-water-cooling-the-case/#findComment-2981476
AC
I was saying, that you can't "watercool" the case to any temperature lower than room temperature, so if the room gets colder because of AC, then the case will get colder. But will always remain equal to or above room temperature. Unless you want condensation.
https://linustechtips.com/topic/217448-water-cooling-the-case/#findComment-2981491
I was thinking along the same lines of condensation, and now I'm thinking that something like this (obviously not this exact model) would possibly counteract condensation, but its debatable still.
https://linustechtips.com/topic/217448-water-cooling-the-case/#findComment-2981516
