Hi guys
I've been building my pc up for the past year and I am now happy with my rig. I am currently gaming through a old led tv and have decided it's time to get a monitor. I don't have the largest budget so options are limited. I'm looking for a something that preforms reasonably well and looks good for around £250. I have looked briefly and I have come across the asus vx279q. What are your thoughts on this and what alternatives can people suggest?
Thanks for any help :)
https://linustechtips.com/topic/217371-display-choice-help/
https://uk.pcpartpicker.com/part/lg-monitor-29um65p
I wouldn't go too big on 1080p. 24" would be ideal for 1080p. If you want a bigger display, go 1440p or 4k, which is out of your range, so I would either get the 21:9 LG that I posted above or a simple 24" 1080p display.
https://pcpartpicker.com/part/asus-monitor-pb238q
This one has a nice stand, performs well in games and is also IPS.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/217371-display-choice-help/#findComment-2980386
https://linustechtips.com/topic/217371-display-choice-help/#findComment-2980436
