I'm going to bottom out the keys regardless.
Have o-rings to help with noise.
Which would be better for someone who isn't going to care about the actuation point?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/216475-red-or-brown-switches/
How noticeable are the browns?
I'm going to push all keys right to the bottom (the o-ring)
I'm not sure if the bump is going to be annoying or not since I will press them all the way to the bottom regardless.
I have no way to test other than buy a key tester which I can't get in the UK for a decent price.
https://linustechtips.com/topic/216475-red-or-brown-switches/#findComment-2966659
You don't have to bottom out with O-rings I run a brown with rings on it to stop the noise when I do bottom out (which is rare for me) but still love the actuation point without the rings. Maybe it is just me as I am a tactile guy and only went brown to satisfy work place noise complaints :)
https://linustechtips.com/topic/216475-red-or-brown-switches/#findComment-2966741
I'd go browns.
The bump won't be annoying. If you press too hard you might not even feel it. It's when you're deliberately trying to type as softly as possible that you'll feel it the most and know where to stop.
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
https://linustechtips.com/topic/216475-red-or-brown-switches/#findComment-2966897
I mean if you truly don't care about the actuation point, reds are the way to go, since you can't feel it. If you want to be able to feel the bump (and lift the key before bottoming out), then I would recommend browns. Since you say you plan on bottoming out the key every time, I just say go with reds.
"Never trust the authenticity of a quote on the internet."
   -Abraham Lincoln
https://linustechtips.com/topic/216475-red-or-brown-switches/#findComment-2967029
