I just installed Elementaryos on my other desktop and i don't know why my ethernet is not working, i had ubuntu installed and it worked find but i am going to be giving this system to my parents and elementaryos is lighter and easier to use so i installed it i have been trying to get ethernet to work so that i can connect to the internet and it won't work the computer specs are here http://pcpartpicker.com/p/VL7623
the parts are all HP OEM parts and i thought it was a problem with the drivers but i can only find the ethernet driver for that board for windows and i am familiar with linux but i am not a pro yet, please help any suggestions would be greatly appreciated
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/215609-elementary-os-ethernet-not-working/
Use another lightweight distro that will support most gigabit ethernet chipsets out of the box, like Linux Lite.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
i can't really use any because all of my dvd discs are too small and my USB's are all corrupted and if i use another lit linux it would be linux mint and thank you for the suggestion but i am actually trying to fix the problem
Use the HP USB Disk Storage Format tool to fix your corrupted USBs. You can download and install the program here.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
i mean the usb device wont even pop up anywhere on my computer so i can't use that it won't detect it but thanks
If you mount the installation of an OS on a USB, they sometimes tend not to show up when you plug them in. Check if your USB is detected in your BIOS. If it is, then you should be able to restore it using the utility. You can also check disk management (in windows) or whatever disk utility program there is in Elementary OS to see if your USB is detected. You should also be able to repartition your USB in whatever disk utility program you have.
~Slick
I run mint on my old laptop and it works great :)
If you've previously won the build off please pm me so we can get something worked out.
i had the os on a dvd and installed it that way
Use USBs. They're much faster to install and you can reuse them.
~Slick
well every time i use the USB's they get corrupted and they don't work anymore but i will try to fix it more tomorrow, thanks for the help
If the USB shows up in your BIOS, it's very likely you can fix it. Check in if the USB is listed under the disk utility program for Windows (disk management) or Elementary OS. Try running the program I provided a link to earlier on in this topic. I can't see how you can use a USB just once to install an OS and never be able to use it again. I've used a USB to install over 10+ operating systems from it and it works fine every time. I just give that program a run, select the USB, and then it's like new again.
Please at least try using the program before saying anything :)
Just tryin' to help ya.
~Slick
