Laptop does not turn on?
Go to solution Solved by FakezZ,
Now I'm kinda pissed... Fuck that I'm installing ubuntu on that shit and I'm just gonna stream games from my desktop. -.-
Okay so I was using my laptop and suddenly the keyboard stopped working(mouse worked just fine). So I selected restart(there was a windows update, so that was done) and it got stuck at the restart thing spinning. I left it for half an hour and it was still stuck, so I shut it down manually using the power button. The it was not booting not even in the bios. It was just lighing up and shutting down after 4-5 seconds. Then I unplugged it and removed the battery. Then it booted up normally, but neither the mouse(or touchpad) nor the keyboard were working and shortly after (like 20 seconds) I got a blue screen with the error "DPC_WATCHDOG_VIOLATION". After that it does the same thing described before when it wouldn't even start up the bios. Any suggestions? Specs of the laptop:
i7 2720qm
gtx 460m
500gb HDD
Windows 8.1 Pro
8gb 1333mhz ram
1080p screen(probably not useful in troubleshooting, but oh well...)
MacBook Pro 15' 2018 (Pretty much the only system I use)
https://linustechtips.com/topic/214752-laptop-does-not-turn-on/
