So should I get af or sp fans, only making sure before purchase one.
Af = air flow meaning not in use with radiators.
Sp = static pressure or used with radiators.
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/214182-need-help-with-case-fan/#findComment-2929977
Can't view it not enough battery left on phone. Will answer when I get home
https://linustechtips.com/topic/214182-need-help-with-case-fan/#findComment-2930015
Go ahead, I have the same ones. They run quiet and effectively
CPU: Intel i5 4440 @3.1 GHz, Mobo: Gigabyte GA-H87M-D3H µATX, RAM: 2x4GB Corsair Vengeance 1600MHz,
GPU: XFX Radeon R9 280X,Storage: 120GB Samsung 840 EVO and 1TB Seagate HDD,
PSU: Corsair CX750M, Case: Fractal Design Arc Mini R2
https://linustechtips.com/topic/214182-need-help-with-case-fan/#findComment-2930027
AF140 Quiet Editions are decent enough fans.
You could have quieter with a Cougar CFV14HB, or more airflow with a 140mm Bitfenix Spectre Pro or a Rosewill Hyperborea.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/214182-need-help-with-case-fan/#findComment-2930235
@Marmike16
^^^ This is what I would recommend ^^^
https://linustechtips.com/topic/214182-need-help-with-case-fan/#findComment-2930645
