Problem installing Malwarebytes
Go to solution Solved by FizzyFantom,
If you haven't already you should take a look at this thread:
https://forums.malwarebytes.org/index.php?/topic/149048-internal-error-expression-error-runtime-error-at-79177-external-exeption-e06d763/
Doing a clean removal and a fresh installation may help, instructions for this can be found here:
https://forums.malwarebytes.org/index.php?/topic/146017-mbam-clean-removal-process-2x/
Best of luck :)
Best of luck :)
"PSU brands are meaningless, look up the OEM."
