Okay time to build a computer for the start of college. I need some help choosing parts.
  1. Budget: My budget is around US $1600.
  2. Aim: Mainly used for high end gaming and college programing
  3. Monitor: Planing on using a single 24’’ 2ms monitor
  4. Peripherals: Need a gaming keyboard, but already have mouse and audio
I really like the design of the Corsair 240 Air and would like to use it. I would also like to run most high end video games at max or near max graphics at 60 frames per second. I don’t need to buy an operating system, mouse, or speakers. I’d like to use a 1tb storage with a 128gb ssd. 8 Ram is plenty. I might upgrade to 16 later though. I'd like to go with liquid cooling, but it all depends on the total price.
That being said, please help me choose the CPU, CPU cooler, motherboard, power supply, and graphics card. Thank you so much!
https://linustechtips.com/topic/212473-first-college-computer-build-help/
Alright, gimme a sec.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($339.93 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($94.99 @ NCIX US)
Motherboard: Asus GRYPHON Z97 Micro ATX LGA1150 Motherboard  ($161.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 780 3GB Video Card  ($510.99 @ SuperBiiz)
Case: Corsair Air 240 MicroATX Mid Tower Case  ($89.99 @ Amazon)
Total: $1536.84
Generated by PCPartPicker 2014-09-10 00:46 EDT-0400
Specs
PCPartPicker part list: http://pcpartpicker.com/p/86C8P6
Price breakdown by merchant: http://pcpartpicker.com/p/86C8P6/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($209.99 @ Amazon)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($136.99 @ SuperBiiz)
Motherboard: Asus Z97-AR ATX LGA1150 Motherboard  ($149.99 @ TigerDirect)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory  ($92.99 @ Newegg)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Drive  ($69.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ OutletPC)
Video Card: Asus GeForce GTX 780 Ti 3GB DirectCU II Video Card  ($557.99 @ SuperBiiz)
Case: Corsair Air 540 ATX Mid Tower Case  ($119.99 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ Micro Center)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  ($111.99 @ Amazon)
Total: $1573.89
Generated by PCPartPicker 2014-09-10 00:48 EDT-0400
wow, thats a lot of bees!
Total: $1536.84
This is the build I would go with personally.
If you've previously won the build off please pm me so we can get something worked out.
boop
they requested the 240
Specs
http://pcpartpicker.com/user/EnthusiastGaming/saved/yTWJ7P
Its a bit under but ummm.. I found it hard to get it to $1600 cause I live in AUS and I'm always making budget builds
EDIT: but you could upgrade to a 4790k and maybe get a 290 if you wanted.
You do realize you can change the dollar amount into USD like he wanted right? -.-
Your build:
Motherboard: Asus Z87-K ATX LGA1150 Motherboard  ($124.98 @ Newegg)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($76.99 @ Amazon)
Video Card: EVGA GeForce GTX 770 2GB ACX Video Card  ($328.52 @ Amazon)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Amazon)
Monitor: Asus VX248H 60Hz 24.0" Monitor  ($164.00 @ Newegg)
Total: $1199.45
Generated by PCPartPicker 2014-09-10 01:16 EDT-0400
Not to be insulting or offensive but for the money you can do better.
Motherboard: Asus Z97M-PLUS Micro ATX LGA1150 Motherboard  ($124.99 @ Amazon)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory  ($74.70 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: EVGA GeForce GTX 780 Ti 3GB Superclocked ACX Video Card  ($618.80 @ Newegg)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($98.97 @ OutletPC)
Keyboard: Corsair Vengeance K90 Wired Gaming Keyboard  ($133.00 @ Mechanical Keyboards)
Total: $1559.41
Generated by PCPartPicker 2014-09-10 01:24 EDT-0400
Your build:
Total: $1199.45
yeah I know I did, but I just don't know if I can justify using $1600 when he's probably only doing gaming and school work :3
Hmm...I can see it. But then again my personal computer is about 4.5 grand atm as well, without custom water cooling, which will come later.
Oh god the jealousy right now...
Total: $1536.84
Would recommend this build ^^
dude what
