I recently decided to build a custom PC. Turns out I don't 100%  know everything I need to know about to build a PC. So far I have bought a NZXT Phantom 410 case, and an MSI B85-G41 motherbored. And I have a pretty strict buget at about 2000 including the case and mother bored, I wanted to have a triple monitor setup. What do I do??? Someone help me. Thanks.
https://linustechtips.com/topic/211999-building-pc/
Are keyboard and mouse required, I'm almost done for the build.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/211999-building-pc/#findComment-2877857
I have those picked out already, Thanks.
I'm thinking something along the lines of
CPU Cooler: Scythe SCNJ-3100 110.3 CFM CPU Cooler  ($44.98 @ OutletPC)
Motherboard: MSI B85-G41 PC Mate ATX LGA1150 Motherboard  (Purchased For $80.00)
Memory: GeIL EVO Veloce Series 16GB (2 x 8GB) DDR3-1866 Memory  ($127.24 @ TigerDirect)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.99 @ Micro Center)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($99.99 @ Dell Small Business)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card (2-Way CrossFire)  ($349.99 @ NCIX US)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case  (Purchased For $80.00)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($119.99 @ Newegg)
Total: $1991.96
Generated by PCPartPicker 2014-09-09 01:24 EDT-0400
https://linustechtips.com/topic/211999-building-pc/#findComment-2877880
Total: $1991.96
Thanks so much for the help!
https://linustechtips.com/topic/211999-building-pc/#findComment-2877893
750w is a little low for r9 290 crossfire. The 850 or 1000w model of that power supply should be used instead
i7 4770k currently @ stock | 2x Sapphire r9 290 Tri-x in crossfire | 16 GB GSkill trident X @ 2400 Mhz | Asus z87 Sabertooth | NZXT h440 | NZXT Kraken x60 | Corsair RM1000 | BenQ XL2420TE
https://linustechtips.com/topic/211999-building-pc/#findComment-2878108
