R9 290 Issue
Go to solution Solved by Windows98SE,
The RAM on the card is probably bad. It would result in the problems you described.
Like everyone else already said, RMA the card.
Recently I purchased an R9 290 Sapphire Tri-x 4GB. The card was performing well originally. As time passed I played battlefield 4 and it crashed occasionally. A few times it crashed on battlefield and I even got blue screen. Also, a few days ago when I started up games like diablo 3 or battlefield, etc I noticed some horizontal lines for a few seconds and then they left. I also noticed these lines when I left the games. Yesterday, all of a sudden the computer crashed on battlefield and got blue screen. I restarted but then the screen was flickering unstoppably. I searched the issue and was told to uninstall the 14.4 driver and install an early one (13.12 whql driver). Today everything was alright until I noticed a few horizontal lines here and there around my screen. Btw, the horizontal lines have colours. What should I do? Btw, I don't know how to flash the gpu or anything too complicated.
My system Specs:
Processor= i5 4670k 3.4ghz
Cooler= Corsair H100i
Mobo= Gigabyte Z87m-ud3h
RAM= G Skill Ripjaws 2x8 16gb 1600mghz
PSU= Corsair GS 700W
HDD= Intel 520 Series SSD 180gb + WD 1tb caviar black
https://linustechtips.com/topic/211183-r9-290-issue/
I can't really tell..exactly but from my experience I think you should check your temperatures. I had the same issue some months ago when I would open Diablo 3 as you said and after a lot of stuttering the PC would turn off by itself because of the temperatures. Might be wrong but it's worth the check.
https://linustechtips.com/topic/211183-r9-290-issue/#findComment-2866384
Did you buy it new or used?
Contact Sapphire and RMA it.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/211183-r9-290-issue/#findComment-2866385
I got a new card. Is there certainly no solution??
It's likely defective. An RMA with sapphire is your best option.
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/211183-r9-290-issue/#findComment-2866525
