Unidentified Network when using Powerline
Hey I recently bought a NetCommWireless 200Mbps Powerline Adapter with AC Pass-through and hooked it up. I connected everything correctly and the adapter shows all 3 green LEDs are lit indicating that they are both linked and that everything is working, but when I check on my computer it says "Unidentified Network" and "Limited Connection". When I check on control panel it says "Unidentified Network" and the access type is "No network access". I checked on my Ethernet Status and it states the following:
Connection
IPv4 Connectivity: No network access
Media State: Enabled
Duration: 00:07:04
Speed: 100Mbps
Activity
Packets 356 I 0
https://linustechtips.com/topic/210444-unidentified-network-when-using-powerline/
Connection
Duration: 00:07:04
Speed: 100Mbps
Activity
Packets 356 I 0
Interesting, I haven't had that problem with the 200s we used to have or the 500s I upgraded too when we added more devices.
Does it work if you try the adapters when they're plugged in next to each other on a power board?
What do you mean?
