What can cause a graphics card to not output to the display. For example 2 6970's not in crossfire, connect 6970 number 1 in the PC and it works fine, remove and connect 6970 number 2 and nothing is shown on the display, the fan still spins.
Also is it possible that i could still use a graphics card that doesnt show anything on display as a second card for crossfire and use perfectly working one in slot 1 to output to display?
PC 1 Specs (New) :
Corsair 450D | Intel 4770K | Asus Sabertooth Z97 | 16GB Corsair Vengeance @1600Mhz | Asus STRIX GTX 970 SLI | Samsung 840 EVO 250GB | 2 WD Black 500GB RAID 0 | WD Red 3TB | Corsair AX860 | Corsair H110 | 4 Corsair 140mm LED & 1 120mm Fans
PC 2 Specs (Old) :
Corsair 650D | AMD Phenom II X6 1100T | Asus Crosshair IV Formula | 4GB Corsair XMS3 @1600Mhz | Crossfire HD6970's | Asus Essence STX | OCZ Agility 3 240GB| WD Blue 250GB | WD Green 640GB | XFX850PRO | Corsair H100i
Peripherals :
BenQ 2420T | Packard Bell Viseo 220DX | Corsair K70 | Corsair M65 | Beyerdynamic DT880 Premium | Sennheiser PC360 | Bang & Olufsen Beovox X25's
https://linustechtips.com/topic/20992-hd6970s-problems/
Have you tried other outputs on the card?
It's possible that only the outputs are problematic and it may still run in CF, you'd just have to test it.
Desktop - Custom watercooled R4E/i7 3930k/GTX 780 SLI/32gb 2400mhz DDR3/Xonar STX/OCZ V4 256gb RAID 0/24tb RAID 5
Laptop - Clevo P370EM - i7 3630QM/GTX 680M SLI/8gb 1866mhz DDR3/840 pro 256gb RAID 0/750gb mechanical
https://linustechtips.com/topic/20992-hd6970s-problems/#findComment-252452
