As I've migrated to a PC platform for gaming, I'm trying to get adept with mouse and keys. I've noticed something quite annoying though. With sticks I'd walk around and smoothly rotate the camera to take in the scene, sometimes I'd rotate very slowly and it always seemed buttery smooth. With my mouse though, I can see the camera snap with each pixel my mouse moves to, making the rotating jaggy and unnatural. I use the corsair m65 usually just shy of 2000dpi. How can I achieve a smooth camera experience?
2014 - EVGA 780 SC ACX | 4790K | Asus Sabertooth Z97 Mark 1 | Vengeance DDR3 1600MHz 16GB | RM650 | Be Quiet! Dark Rock Pro 3 | VGA248QE | Fractal Define r4
2015 - EVGA 980 | 4790K | Asus Sabertooth Z97 Mark 1 | Vengeance DDR3 1600MHz 16GB | RM650 | NZXT X41 | Asus ProArt 1080p IPS | Fractal Define r4
2017 - MSI Gaming X 1080 Ti | 6600K | Strix z270e | Trident DDR4 3GHz 16GB | RM650 | NZXT X42 | LG OLED B9 | Dell U3415W | Corsair Crystal 460x
2021 - MSI Gaming X 1080 Ti | 5600X | Strix B550-F | Trident Neo DDR4 3.6GHz 32GB | Dark Power Pro 12 1500W | EK AIO Basic 360 | LG OLED B9 | Dell U3415W | Corsair 5000D Airflow
2023 - Asus TUF 4090 | 5800X3D | Strix B550-F | Viper DDR4 3.6GHz 32GB | RM1000x | h150i 360 Elite LCD | LG OLED B9 | Dell U3415W | Corsair 5000D Airflow
https://linustechtips.com/topic/209906-specific-mouse-vs-stick-attribute/
It can be hard to make a very slow and smooth mouse movement over a short amount of physical space, try lowering your mouse DPI and making broader sweeps with your hand if you want slow and smooth rotation.
Otherwise you  can always use a controller, I prefer mouse and keyboard but some games are just better with a controller because that's what they're made for.
Some games have mouse cursor/camera smoothing, but it won't exactly benefit you when you try to aim on things.
Case: Fractal Design R4  Motherboard: Asus Z87-Plus  Processor: Intel i7 4770K  GPU: MSI GTX 1070 Gaming X  RAM: Corsair Vengenace Pro 16GB  PSU: Be Quiet Dark Power Pro 10 750W  SSD: Samsung 850 Evo 500GB   Monitor(s): LG 24GM77  Keyboard: Logitech G410  Mouse: Zowie EC1-A  Mousepad: Puretrak Talent White Ed.  Headset: Kingston HyperX Cloud II
Ya, some googling showed me that devs are looking into it for their code. It seems it's just not quite possible for a mouse.. In a perfect world we could have the accuracy of a mouse with the smoothness of sticks.
Can I ask which game you are playing? The problem could be fixed by changing an in-game setting.
Or it could be caused by the mouse not using a high enough update frequency, I am not so sure of this however, check your mouse settings.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
I've noticed it in Metro LL and BioShock. I'm not sure the update frequency would fix it as it's moving a pixel at a time which I can see the abrupt jump from one pixel to the next, granted only when moving very slowly.
If it is occurring in several games it could be a frame-rate issue as well. Or more specifically the frame-rate changing slightly. I can't be sure.
Something like mouse smoothing for the mouse would probably make the game look allot less jaggy. As far as I know most people don't like that feature however.
I am rather certain that it will come down to the DPI being too high. I am using 2500DPI on my mouse and BF4 sniping is affected by a similar thing. If I focus properly I can minimize the effect, but it still affects me when using a large zoom scope. I am far too used to a DPI of 2500, any slower feels just way too slow.
The only solutions that come to mind are 1. Lower the DPI and increase the in-game sensitivity. 2. Use mouse smoothing.
Ok, thanks for the tips.
