Hi there,
I copied a the files from one external HDD (Journaled) to another external HDD
(NTFS) using the Paragon Software.
The size of all the files was 1.39 TB.
I did this, because I want to cut the media on the drive on my Windows Computer.
Because Journaled and NTFS systems are not really compatible an even though
Paragon does a great job, I wanted to be sure an checked the Size of the files:
The Size of the Original HDD was slightly larger than the file size on the
NTFS formatted HDD (see picture).
Is that anything to worry about? Di something got lost?
I hope you understand what my problem is.
Thanks for the help
Windows 8.1 / i7 4930k / ASUS P9X79 / Gigabyte 770 4GB / Corsair H100i / G.Skill 32 GB 2133mhz RAM / Cooler Master V850 / 250 GB SSD C-Drive
https://linustechtips.com/topic/209655-hdd-size-problem/
