Python Help!
Go to solution Solved by X1XNobleX1X,
Completed with this:
line = input('Line: ')
words = line.split()
line = line.lower()
lwords = line.split()
if 'cat' in line:
  if 'cat' not in lwords:
    print('There is a hidden cat in the line.')
  else:
    if 'cat' in words:
      print('There is a small cat in the line.')
    elif 'CAT' in words:
      print('There is a big cat in the line.')
    else:
      print('There is a medium sized cat in the line.')
else:
  print('No cats here.')
Hello,
In a little trouble with my current question.
THis is what I have at the moment.
cats = input("Line:")
catstwo = cats.split()
if "cat" in cats.lower():
  if "cat" not in catstwo:
   print("There is a hidden cat in the line.")
  else:
    if "cat" in catstwo:
       print("There is a small cat in the line.")
    elif "CAT" in catstwo:
       print("There is a big cat in the line.")
    else:
       print("There is a medium sized cat")
else:
 print("No cats here")
  This is what it must produce:'
  • If the word cat occurs in all lowercase letters in the line, print out: There is a small cat in the line.
  • If the word cat occurs in all uppercase letters in the line, print out: There is a big cat in the line.
  • If the word cat occurs in the line in any combination of upper and lowercase letters, print out: There is a medium sized cat in the line.
  • If the letters cat occur in the line but not as a distinct word, in any combination of upper and lowercase letters, print out: There is a hidden cat in the line.
  • Otherwise, if none of these conditions hold true, you should print out: No cats here.
Your program should work like this:
Line: There's the cat from next door.
Here is another example:
Line: The CaT ran down the stairs.
Here is a third example:
Line: Education is very important.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/208830-python-help/
line = line.lower()
if 'cat' in line:
  else:
    if 'cat' in words:
    else:
else:
https://linustechtips.com/topic/208830-python-help/#findComment-2836021
