This is just really killing me right now, because I've installed this program on two different machines in my house with no hitches. But whenever I try to install this program on my main desktop in my room, which is what I use the most, Citrix Receiver simply will not install at all. It simply fails and states "Object already exists." Not quite sure if this is something anyone is capable of helping me with, but I figured it was worth a try. I'll attach the log file it sent back of the script run in case that helps. Really kind of frustrating because I need this program to do some of the assignments for my VoIP class :(
jhgv.txt
https://linustechtips.com/topic/208777-citrix-receiver-installation-issue/
I've had this problem with Citrix receiver in past. What you have to do is go into the AppData folder on a working computer and then the one on the computer that doesn't work. You have to copy everything in the text-based files on the working computer to the ones on the not working computer. That should fix it. Tell me if you need more clarification.
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
