Hey guys, looking into doing my first custom loop, and pretty much would like a full list of what you guys would recommend no real budget, but nothing ridiculous, im not sure exactly how much tubing and fittings im going to need too. Im cooling my gpu (r9 295x2), cpu (socket-lga 2011), and perhaps my ram mainly for aesthetics. For the rads i can only fit a 1x240mm and 1x280mm and maybe a 120mm perhaps 2 case is the node 804. Also looking for rigid acrylic for the tubing, and already own fans.
specs of my build
case-node 804
psu-ax1500i
gpu-r9 295x2
cpu-4930k
mobo-asus rampage iv gene
memory- corsair vengeance 2133 c9 4x4 but open to buying different.
https://linustechtips.com/topic/208632-parts-list/
(No greeting..kidding) What's your budget? Corrected* no budget. What case do you own? Node 804 got'cha, any other specs?
Guessing you have a Rampage 4 Gene? + 3930K/4930K? (or not)
I'd mount a dual 120/140mm with a radiator thickness of 60-80mm in the hidden chamber. You can also add an extra slim single or dual 120mm rad in the main chamber.
Edited by wng_kingsley7
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/208632-parts-list/#findComment-2830857
