2 psu's ? Need help asap :D
Solved by ForsakenLive,
The 4-pin connector that plugs into the motherboard is the exact same connector as the 4+4pin you will find on the 750W PSU.
Power-hungry motherboards use a 8 pin power connector now, and higher wattage PSUs have a 4+4 cable, you can split up this cable and plug the 4 pin into your motherboard
The connector should look like this:
Sometimes they are found bound by a plastic latch into a 8 cable connector, just separate them and plug the CPU1 power 4 pin power connector. If they are not labeled, don't worry, only the CPU 1 will fit in the socket.
