Hi guys.
Got a question. I've got blocks for my CPU (FX 8150) and the northbridge (AMD 990FX chipset) and a 80mm thick 360mm rad in push/pull.
What is a good flow rate i should look for in my pump. Is 500-700lp/h suitable
Thanks guys.
"Don't make a girl a promise, if you know you can't keep it" | "Didn't you hear? Spartans never die."
-Gaming- FX 8150 @ 4.2GHz, HD 7870 Tahiti LE 2GB @ 1.1GHz, ASRock 990FX Extreme3, 8GB DDR3 1333 MHz, WIndows 10, Custom Watercooled, NZXT Switch 810
-Audio Editing/Mixing- Mac Mini Late 2014, Core i7 3.5Ghz, 8GB RAM, 2TB Fusion Drive, OSX 10.12 El Captain -Phone- HTC One M7 32GB
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/
Flow rate doesn't work like that. What you put there is the maximum low rate of the pump. Different pumps have different flow rate vs restrictiveness curve.
In terms of pumps get a Laing pump, don't cheap out. Both Laing pumps available will be fine for this loop. Laing pumps are incredibly reliable and perform very well.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/#findComment-248528
http://specialtech.co.uk/spshop/customer/Magicool-12V-DC-Deep-Quiet-Pump-Station-700-pid-15165.html
I was looking at this. Any thoughts?
The Laing pump I would chosse is the "Laing DDC 3.25 Pump 900L/h" (http://specialtech.co.uk/spshop/customer/Laing-DDC-325-Pump-900Lhr-18W--DDC-325-pid-15942.html and then couple it with an MCRES Micro Rev 2.
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/#findComment-248562
Well you know what I'm going to say; go for the laing pump, you will not be dissapointed. Besisdes that what you picked is perfectly fine. Its important to note that all DDC and D5 pumps are Laing, if you ever want to pick a cheaper/more expensive pump..
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/#findComment-248784
No other pumps compare to the Laing D5. Get one and save yourself a lot of stress thinking that your computer might die in the middle of a gaming session... Horrible to have that happen...
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/#findComment-248829
The DDC has exactly the same MTBF. Its just as good. In fact iirc all DDC pumps come with a tacho/rpm wire so they are arguably more reliable.
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/#findComment-248850
Yeah, I forgot about the DDC... Thanks for the reminder.
https://linustechtips.com/topic/20755-reccomended-pump-flow-rate/#findComment-253450
