hi recently got a dell inspiron 17 5000 series with a gt 840M 2GB, i7 and 8 gb ram. when i plug it in i can play all my games but the problem is as soon as I unplag it my fps drops is there a way to set my GPU to use the more power in battery mode and run the same as if  was pluged in?
https://linustechtips.com/topic/206343-laptop-gpu-help/
Go into the power settings and there should be an option somewhere where it runs at a lower performance when on battery--change that.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/206343-laptop-gpu-help/#findComment-2800393
go to energy options and put in high performance mode
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/206343-laptop-gpu-help/#findComment-2801779
