Just a quick question hoping to get it answered quickly
How many characters is in the answer of Project Euler 1?
My current total has 8 Characters in it,
Looking for a Programming Project take a look here!
http://linustechtips.com/main/topic/407332-looking-for-a-project-idea-start-here/
https://linustechtips.com/topic/206185-project-euler-1/
(Did it two days ago :P  )
Ryzen 7 5800X     Corsair H115i Platinum     ASUS ROG Crosshair VIII Hero (Wi-Fi)     G.Skill Trident Z 3600CL16 (@3800MHzCL16 and other tweaked timings)
MSI RTX 3080 Gaming X Trio    Corsair HX850     WD Black SN850 1TB     Samsung 970 EVO Plus 1TB     Samsung 840 EVO 500GB     Acer XB271HU 27" 1440p 165hz G-Sync     ASUS ProArt PA278QV     LG C8 55"     Phanteks Enthoo Evolv X Glass     Logitech G915      Logitech MX Vertical      Steelseries Arctis 7 Wireless 2019      Windows 10 Pro x64
https://linustechtips.com/topic/206185-project-euler-1/#findComment-2798628
  • 1 month later...
Thanks...
Probably shouldn't Write the total to the Console every time...
Took a break off of this, and decided to try again. :P
I'm sure theirs nothing wrong with this: (C++)
#include <iostream>using namespace std;int main(){    int sum, upto, c;    upto = 1000;    for (c = 0; c <= upto; c++){        if (c % 3 == 0 || c % 5 == 0){                // Save that nanoseconds worth of time.            if (c % 3 == 0 && c % 5 == 0) {                sum = sum + c;                cout << "3 & 5 are multiples of " << c << endl;            } else {                if (c % 3 == 0)                {                    sum = sum + c;                    cout << "3 is a multiple of " << c << endl;                }                if (c % 5 == 0)                {                    sum = sum + c;                    cout << "5 is a multiple of " << c << endl;                }            }        } else {            cout << c << " Checked." << endl;        }    }    cout << sum << endl;    return 0;}
https://linustechtips.com/topic/206185-project-euler-1/#findComment-3172965
Because 3 & 5 would be multiples, will try without.
Edit: Still wrong will edit above post.
You never initialize sum to 0, depending on your compiler that could be the problem, without the *2 it comes up with the correct solution for me.
1474412270.2748842
https://linustechtips.com/topic/206185-project-euler-1/#findComment-3173267
I initialized the sum and removed the *2, I'm assuming that I'm much closer to the answer (234168).
Not sure what could be wrong at the moment.
https://linustechtips.com/topic/206185-project-euler-1/#findComment-3173328
You changed
for (c = 0; c < upto; c++){
to
it was right the first time.
1474412270.2748842
https://linustechtips.com/topic/206185-project-euler-1/#findComment-3173381
You changed
to
Aye, Thanks :)
Just realized that, the code above could be compacted to 20 lines. ...
Edited by AustinB
https://linustechtips.com/topic/206185-project-euler-1/#findComment-3173422
